Beats Solo 3 Headband Replacement
  1. Beats Solo 3 Headband Replacement, Headband: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Beats Solo 3 Headband Replacement, Headband: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Beats Solo 3 Headband Replacement, Headband: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully partially remove the headband cushion cover. Be careful not to rip the two headband eyelets just above the screws on each end of the headband.
  2. Beats Solo 3 Headband Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Solo 3 Headband Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the main part of the cover off, pull the head band cover up and out of the metal headband ends, exposing the screws underneath.
  3. Beats Solo 3 Headband Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Beats Solo 3 Headband Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Beats Solo 3 Headband Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all four 1.4 mm screws on the right and left ends on the underside of the headband using a T5 Torx screwdriver.
  4. Beats Solo 3 Headband Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the metal headband end out from the headband slightly, and disconnect the rubber band from the hook.
  5. Beats Solo 3 Headband Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Beats Solo 3 Headband Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the inner headband by gently prying the edges and corners.
  6. Beats Solo 3 Headband Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel up the glued wire in the headband.
  7. Beats Solo 3 Headband Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the headband out of the slots gently.
    Be very careful when you pull the headband. There are small pin in the hinge mechanism and they will come out. You will need very small tweezers to put them back in and it is not trivial as the space is very limited. It took me nearly 1 hour to put them back in!
    Marc66 - crwdns2934203:0crwdne2934203:0
  8. Beats Solo 3 Headband Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the new headband into the slots carefully.
    But what happens after? It sounds like we might need to clue the parts back together?
    Sand - crwdns2934203:0crwdne2934203:0
Joseph Konadu
crwdns2935283:003/24/21crwdne2935283:0
211 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G13, Riel Spring 2021 crwdns2935289:0UMass Dartmouth, Team S1-G13, Riel Spring 2021crwdne2935289:0
UMASSD-RIEL-S21S1G13
help when i was putting on the new headband the snap on middle parts fell out and i cant put them back in (the metal connection parts)
koro - crwdns2934203:0crwdne2934203:0
same it happen to me as well
Bardo -
can't find screws and can't locate size to purchase new ones
Kiann Delaney - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 188
crwdns2942667:0crwdne2942667:0 13,805
