Bear 1000 Power Entry Module Replacement
    1. Bear 1000 Power Entry Module Replacement, Air and O2 Blender: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the ribbon cable at the connection on the oxygen blender control board.
    2. Bear 1000 Power Entry Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
    3. Bear 1000 Power Entry Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
    1. Bear 1000 Power Entry Module Replacement, Air and O2 Inlet Manifold: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the pneumatic and electrical connections labeled.
      • Remove the water trap bowls on the rear of the unit.
    2. Bear 1000 Power Entry Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four screws and remove the manifold.
      • Remove the two screws holding the power supply to the manifold.
      • Mark or label the 6 faston connections as to position and remove
      • Mark or label the two wires going to the power switch and remove at the power switch end
      • Using an allen wrench, remove the power cord retaining bracket.
    1. Bear 1000 Power Entry Module Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using an allen wrench, remove the mounting screwa and nuts from the Power Entry Module.
      • After removing the heat shrink tubing, unsolder the two lower wires from the Power Entry Module, noting locations.
      • Solder the wires to the replacement module, covering the joints with heat shrink tubing.
      • Transfer the voltage selector drum from the original module to the replacement and reinstall.
Eli Ferman
crwdns2935283:004/08/20crwdne2935283:0
607 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G12, Paton Fall 2020 crwdns2935289:0Cal Poly, Team S7-G12, Paton Fall 2020crwdne2935289:0
CPSU-PATON-F20S7G12
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 320
