This guide will walk you through the process of replacing a spent fuse in a Bear 1000 Ventilator. Found on page 89 in the full service manual.
Use a screwdriver to push in and turn the fuse holder counterclockwise until it disengages.
Retain the cap which holds the fuse, and replace the fuse in the cap with a new appropriately rated fuse.
Insert the cap back into the ventilator.
Using a screwdriver, press it in, and rotate it clockwise.
