This guide will walk you through the process of replacing the ambient air intake filters in a Bear 1000 Ventilator. Found on page 97 in the full service manual.
Turn off the ventilator and disconnect from AC power and pressurized gas at the wall sources.
Open the ventilator by removing the console retaining screw.
Vacuum all surfaces inside the ventilator. Be sure to reach areas around connectors, circuit boards and pneumatic assembies.
Remove old filters in back panel and replace with new ones.
