Bazic 3003 Battery Replacement
  1. Bazic 3003 Battery Replacement, Bazic Calculator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the "OFF" button on your Bazic 3003 calculator.
    • Make sure it is powered off before you begin the repair.
  2. Bazic 3003 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn your calculator over so the back is facing up.
  3. Bazic 3003 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 1.0 mm screw from the battery compartment.
  4. Bazic 3003 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only one button battery is needed for the calculator to function but you can add one or two.
    • Use your fingers or a plastic spudger to remove the battery from the calculator.
    • Insert the new button battery into the slot and push it into place.
  5. Bazic 3003 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the battery door.
    • Use a Phillips #0 screwdriver to replace the screw and secure the battery door.
  6. Bazic 3003 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the "On" button on your calculator and check if the buttons work and function properly.
Bryan Reyes
crwdns2935283:003/04/25crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 3-3, Grodsky Spring 2025 crwdns2935289:0CSU Los Angeles, Team 3-3, Grodsky Spring 2025crwdne2935289:0
CSULA-GRODSKY-S25S3G3
crwdns2942667:0crwdne2942667:0 164
