Battery Terminal Replacement
  1. Battery Terminal Replacement, Battery Terminals: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start with a clean work bench
  2. Battery Terminal Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 2.5mm allen key to remove the damaged terminals screws
  3. Battery Terminal Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Terminal Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use some small side cutting pliers to cut and break off as much of the plastic as possible.
  4. Battery Terminal Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Terminal Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inside the terminal there are small plastic teeth that lock the metal pin to the plastic part of the terminal.
    • Use a small screwdriver or blade to bend these teeth out of the way.
    • All need to be bent out of the way in order to remove the plastic part of the terminal.
  5. Battery Terminal Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Terminal Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to wedge out the plastic part of the terminal.
    • Push the metal post back towards batter while removing the plastic part.
    • There is some glue in behind, but no other fixings so it will come out.
  6. Battery Terminal Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect and clean the terminal post.
  7. Battery Terminal Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the end cap of the post.
    • Use a blade to wedge it off.
  8. Battery Terminal Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Terminal Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Line up the flat sides of the new terminal with the flat side on the metal post
    • Place the plastic terminal over the metal post, and use some small needle nose plier to pull the post over the teeth so that they engage
  9. Battery Terminal Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Terminal Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinstall and tighten the screws
    • Reinstall the plastic end cap for the terminal post.
Mark Duyvesteyn
crwdns2935283:002/11/26crwdne2935283:0
1,269 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 94
