Battery Replacement for the Kindle 4
  1. Battery Replacement for the Kindle 4, Opening the case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Replacement for the Kindle 4, Opening the case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use plastic opening tools to pry open the case starting on the long side. The cover has a total of 8 clips, 4 of which (located on the long sides) are designed so they will be damaged when the device is opened.
    You skip how to open the 3rd side, and if the third side to open should be the top or bottom.
    Aporatael - crwdns2934203:0crwdne2934203:0
    515-1058-01 (part #) MC-26536 (model #) for the Kindle 4/5 battery. I got mine from Amazon - came with tool to crack lid.
    ElvinC - crwdns2934203:0crwdne2934203:0
    It is suggested in the overall guide comments that one could unclip all four side tabs and pry up from the middle of the left or right sides to get the two tabs from either the bottom or top out so that you can slide the cover off.
  2. Battery Replacement for the Kindle 4, Loosening the adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After prying open 3 sides of the cover, it is still attached to the aluminium cover by double-sided adhesive tape. Use a screwdriver to create a small gap and use the scalpel to cut the adhesive. Alternatively you can losen the adhesive with a heat gun.
    No adhesive found on my Kindle 5.
  3. Battery Replacement for the Kindle 4, Remove the case cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After loosening the adhesive, the case cover can be easily removed.
  4. Battery Replacement for the Kindle 4, Remove the battery cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two TX5 screws from the battery cover.
  5. Battery Replacement for the Kindle 4, Remove any adhesive residue: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any adhesive residue from the battery cover and the housing cover with a scalpel / rubbing alcohol.
  6. Battery Replacement for the Kindle 4, Disconnect the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then carefully disconnect the battery flex cable, ensuring that the contacts are not being short-circuited.
    Flip up the black plastic clip and that will release the cable.
  7. Battery Replacement for the Kindle 4, Remove the battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is adhered to the housing, it takes some force to remove it. Avoid puncturing of the battery as it could catch fire and/or explode! Dispose of the old battery properly.
    Use a wide flat-head screwdriver here and gradually work your way down to prying the battery free from the adhesive - battery is going to flex and bend. You're not going to want to use that battery again - recycle that old battery.
  8. Battery Replacement for the Kindle 4, Insert new battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The new battery can be fastened through the remaining adhesive residue. Reconnect the flex cable of the new battery, making sure that the contacts are not short-circuited.
  9. Battery Replacement for the Kindle 4, Control function: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The display should indicate a empty battery.
    • Before further assembly, the battery should be fully charged and it should be checked whether the device terminates the charging process when the battery is fully charged. If this is not the case, the new battery could be destroyed by the device.
    • Monitor the initial charge and carry it out in a place where there are no flammable objects.
    Screen may not refresh to show empty battery if the battery is fully drained. It will refresh after a short period of charging when you attempt to power it on.
  10. Battery Replacement for the Kindle 4, Secure the battery cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Secure the battery cover with the two TX 5 screws. Ensure a good fit of the back cover with a few strips of double-sided tape. Limit the amount of tape so as not to hinder future disassembly.
    There wasn't much adhesive on the battery cover when I removed the lid...I skipped putting any tape back on.
  11. Battery Replacement for the Kindle 4, Finish the reassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rear cover will still fit well and tight despite the four missing fastenings.
    Carefully insert top and bottom tabs in, then squeeze down the left and right sides to get everything to snap back in.
crwdns2935229:015crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Sigi Gruber
crwdns2935283:011/28/18crwdne2935283:0
673 crwdns2915208:0crwdne2915208:0
Es sollte m.E. noch ergänzt werden, dass der Deckel an den schmalen Seiten mit je zwei Laschen gesteckt ist. Um den Deckel zu lösen, muss man, nachdem die langen Seiten wie beschrieben geöffnet wurden, ihn etwas nach außen wölben: Man zieht dazu die schmalen Seiten in Richtung der Gehäusemitte, so dass man die Laschen herausziehen kann.
Martin Dauskardt - crwdns2934203:0crwdne2934203:0
By far the worst part is the battery cover is welded to the back of the case with gluonium which cannot be removed with anythhng but gamma rays and kryptonite, so as the guide says,, long thin knife is what you need. The battery is glued in the same but you don’t care so much at this point :-) See step 3, the tabs top and bottom, you remove the cover by flexing it away from the frame at about the mid point.
Time and patience, gently, gently teasy monkey…
Tosspot - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 80
crwdns2936753:030crwdne2936753:0 417
crwdns2942667:0crwdne2942667:0 14,900
