Battery Disconnection
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Battery Disconnection, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power off your phone.
  2. Battery Disconnection, Separate the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Battery Disconnection, Separate the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Battery Disconnection, Separate the back cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A screw‑driven camshaft in the bottom left corner pushes the back cover away from the phone, creating a gap to begin separating the cover.
    • With the back cover facing up, use a T3 Torx screwdriver to turn the screw in the bottom edge counterclockwise until the back cover pops up.
  3. Battery Disconnection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Battery Disconnection: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Battery Disconnection: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before separating the back cover, note the following:
    • There's a seam just under the back cover panel. Don't insert your tool here.
    • Insert your tool completely under the back cover, so it's between the frame and the underside of the back cover.
    • Insert an opening pick under the bottom left corner of the back cover and slide it along the bottom edge to release the clips and separate the adhesive.
    • You should feel and hear the back cover clips release. If you don't, insert the pick deeper and try again.
  4. Battery Disconnection: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Battery Disconnection: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Battery Disconnection: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding the pick under the perimeter of the back cover to fully separate the clips and adhesive.
  5. Battery Disconnection, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Battery Disconnection, Remove the back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Battery Disconnection, Remove the back cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove the back cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • If you're installing a new back cover:
    • Make sure you remove all liners from the underside.
    • Use the flat end of a spudger to press the small cable above the wireless charging coil into place over its alignment posts.
    • Place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
  6. Battery Disconnection, Disconnect the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Disconnection, Disconnect the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the two screws securing the battery connector cover.
  7. Battery Disconnection: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Disconnection: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently flip the graphite sheet on the battery over the top edge of your phone.
    • Be careful not to tear the sheet, as it's very delicate.
  8. Battery Disconnection: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Battery Disconnection: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Battery Disconnection: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger in the notch on the left edge of the battery connector cover and pry up to release its clips.
    • Only insert your tool enough to pry up the cover. Otherwise, you may accidentally disconnect the rear camera press connector.
    • Remove the cover.
    • During reassembly, firmly press the cover into place to engage the clips.
  9. Battery Disconnection: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Battery Disconnection: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Battery Disconnection: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick under the top edge of the battery press connector and pry up to disconnect it.
    • Check if the rear camera press connector got disconnected during the previous step. If it did, reconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119.085 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.724crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 59
