This guide shows how to disconnect the battery in your Google Pixel 9 Pro.
Unplug all cables and completely power down your phone.
Adhesive secures the perimeter of the rear cover to the frame.
Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
Insert the tip of an opening pick in the gap.
Slide your opening pick along the bottom edge to separate the adhesive securing it.
Slide your opening pick up the left edge and along the top edge to separate the adhesive.
Slide your pick down the right edge to separate the remaining adhesive.
Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
Four 5.4 mm‑long screws
One 1.5 mm‑long screw
Use tweezers or your fingers to remove the wireless charging assembly.
Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
Remove the rear cover.
Use a Torx Plus 3IP screwdriver to remove the two screws securing the cable cover:
One 2.3 mm‑long screw
One 5.4 mm‑long screw
Use tweezers or your fingers to remove the cable cover.
Insert the point of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
