This guide shows how to disconnect the battery in your Google Pixel 9 Pro XL.
Unplug all cables and completely power down your phone.
Adhesive secures the perimeter of the rear cover to the frame.
Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
Insert the tip of an opening pick in the gap.
Slide your opening pick along the bottom edge to separate the adhesive securing it.
Slide your opening pick up the left edge and along the top edge to separate the adhesive.
Slide your pick down the right edge to separate the remaining adhesive.
Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
Use tweezers or your fingers to remove the cable cover.
Use the point of a spudger to pry up and disconnect the rear cover press connector.
Remove the rear cover.
Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
Use tweezers or your fingers to remove the cover.
Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
Remove the wireless charging assembly.
Use a spudger to pry up and disconnect the battery press connector.
