Battery Blocking
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Battery Blocking, Unfasten the lower cable shield: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Blocking, Unfasten the lower cable shield: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five screws securing the lower cable shield to the logic board:
    • Two 2.0 mm screws
    • Three 1.3 mm screws
  2. Battery Blocking, Remove the lower cable shield: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers or your fingers to grab and remove the lower cable shield.
  3. Battery Blocking, Unfasten the battery connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Battery Blocking, Unfasten the battery connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
  4. Battery Blocking, Battery connector information: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Battery Blocking, Battery connector information: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Battery Blocking, Battery connector information: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  5. Battery Blocking, Create a battery blocker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Battery Blocking, Create a battery blocker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Battery Blocking, Create a battery blocker: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut two 6 mm wide strips from a playing card or cardstock to use as a battery blocker.
    • The strips should be about 4 cm long so you can easily grip them.
  6. Battery Blocking, Insert the card strips: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Battery Blocking, Insert the card strips: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Battery Blocking, Insert the card strips: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the card strips on each side of the battery connector until they stop.
Chayton Ritter
crwdns2935283:008/21/20crwdne2935283:0
23,266 crwdns2915208:0crwdne2915208:0
crwdns2935297:0105crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:013,420crwdne2935297:0
crwdns2942667:0crwdne2942667:0 80
