Basis Peak Frame Replacement
  1. Basis Peak Frame Replacement, Frame: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
  2. Basis Peak Frame Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Basis Peak Frame Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
  3. Basis Peak Frame Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
  4. Basis Peak Frame Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
Alexander Halliwell
crwdns2935283:003/26/17crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G4, Julie Spring 2017 crwdns2935289:0UMass Dartmouth, Team S4-G4, Julie Spring 2017crwdne2935289:0
UMASSD-JULIE-S17S4G4
crwdns2942667:0crwdne2942667:0 229
