The bands of the Basis Peak allow for several size adjustments for a snug fit to the user's wrist. A properly adjusted band is crucial to the functioning of the sensor on the underside of the watch. If the band is damaged or visibly tarnished, users can easily replace it with this guide. Two spring latches on the underside of the band halves must be released and the band halves will come right off.
Flip the watch over to view the back panel and sensor. Arrange the watch so that the band clasp is away from you.
Release the spring latches on the underside of each band to remove the bands from the frame.
To reattach the bands, follow these instructions in reverse order.
