Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Flip the engine switch to the off position: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Flip the engine switch to the off position: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Close the fuel valve: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Close the fuel valve: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the fuel valve lever to the OFF position.
  4. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Turn off the ignition: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Turn off the ignition: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the ignition switch to the OFF position.
    • Ensure the wheel drive control lever is set to the neutral position.
  5. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Allow the wheels to freewheel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Allow the wheels to freewheel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Allow the wheels to freewheel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
    • Repeat for the left wheel.
  6. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Add wheel chocks: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
  7. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the grease fitting: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an 8 mm socket to remove the outboard bearing grease fitting.
  8. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate bolts: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate bolts: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 9/16 inch socket to remove the four bolts securing the tine shaft to the side plate.
    • Use a 9/16 socket and wrench to remove the five bolts and accompanying nuts securing the side plate to the frame, three on the outside and two in the wheel well.
  9. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Tilt the tiller: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Tilt the tiller: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the tiller up so the motor side is resting on the work surface with the tines raised.
  10. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine cover bolts: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket and wrench to remove the four bolts and accompanying nuts securing the side plate to the tine cover.
  11. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the side plate down and away from the device to remove it.
  12. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine bolts: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine bolts: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine bolts: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The tines closest to the tine drive motor need to be removed in order to allow access to the bolts securing the tine shaft to the hub.
    • Use a 5/8 inch socket with an 11/16 inch wrench to loosen the two 5/8 inch bolts and two 11/16 inch nuts securing the tine to the tine shaft.
    • Remove the two tine nuts.
  13. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two bolts holding the tine to the tine shaft.
  14. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tines: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tines: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tine.
    • Repeat this procedure for all four tines closest to the tine drive motor, opposite the outboard bearing assembly.
    • Keep track of each tine's orientation.
  15. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine shaft bolts: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/8 inch socket with an 11/16 inch wrench to remove the two 5/8 inch bolts and two 11/16 inch nuts behind each removed tine.
    • Repeat this for each of the four tine locations; there are a total of eight bolts to remove.
  16. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine shaft: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine shaft: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine shaft: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tine shaft from the hub.
Carsten Frauenheim
146,626 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,175crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 36
