Backbone One Right Trigger Replacement
Adriana Zwink
crwdns2944109:0crwdnd2944109:0Adriana Zwinkcrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0May 7, 2024crwdne2944111:0
20 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Use this guide to replace the right trigger on your Backbone One.
crwdns2944105:0crwdne2944105:0
  1. Backbone One Right Trigger Replacement, Remove the screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Right Trigger Replacement, Rotate the upper part: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Backbone One Right Trigger Replacement, Rotate the upper part: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Backbone One Right Trigger Replacement, Rotate the upper part: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
    Is there anyway to turn the lightening port to usbc so I don't have to trash mine?
    Frank - crwdns2934203:0crwdne2934203:0
  3. Backbone One Right Trigger Replacement, Remove the protective tape: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Backbone One Right Trigger Replacement, Remove the protective tape: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Backbone One Right Trigger Replacement, Remove the protective tape: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
  4. Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Backbone One Right Trigger Replacement, Open the interconnect cable ZIF connector: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
  5. Backbone One Right Trigger Replacement, Disconnect the interconnect cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Backbone One Right Trigger Replacement, Disconnect the interconnect cable: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable by pulling it straight out the ZIF connector.
  6. Backbone One Right Trigger Replacement, Disconnect the phone connector cables: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Backbone One Right Trigger Replacement, Disconnect the phone connector cables: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Backbone One Right Trigger Replacement, Disconnect the phone connector cables: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
  7. Backbone One Right Trigger Replacement, Separate the upper case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the the upper case of the left controller handle.
  8. Backbone One Right Trigger Replacement, Remove the screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
  9. Backbone One Right Trigger Replacement, Remove the trigger: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Backbone One Right Trigger Replacement, Remove the trigger: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the trigger.
Opening didn’t go as planned? Answers community for help.
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
57,363 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,132crwdne2935297:0
where can I buy a right trigger replacement?
pelony felony - crwdns2934203:0crwdne2934203:0
Ricardo Gazo Rosario - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,080
