Use this guide to replace the face buttons on your Backbone One.
Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
Lift up the upper cover of the controller.
Swing the upper cover over and place it on the controller case.
Is there anyway to turn the lightening port to usbc so I don't have to trash mine?
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
Disconnect the cable by pulling it straight out the ZIF connector.
Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
Separate the the upper case of the left controller handle.
Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
Remove the trigger.
Remove the bumper.
Use a Phillips screwdriver to remove the two 3.9 mm-long screws.
Remove the mainboard.
Use a pair of blunt nose tweezers to remove the rubber cover which is placed over the face buttons.
Use a pair of tweezers to remove the face buttons.
Repair didn’t go as planned? Ask our Answers community for help.
is there any way to do this without taking apart the entire controller?
