Backbone One Direction Pad Replacement
  1. Backbone One Direction Pad Replacement, Unfasten the screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Direction Pad Replacement, Rotate the upper cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Backbone One Direction Pad Replacement, Rotate the upper cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Backbone One Direction Pad Replacement, Rotate the upper cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Direction Pad Replacement, Remove the protective tape: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Backbone One Direction Pad Replacement, Remove the protective tape: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Backbone One Direction Pad Replacement, Remove the protective tape: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Direction Pad Replacement, Open the ZIF connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Backbone One Direction Pad Replacement, Open the ZIF connector: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Direction Pad Replacement, Disconnect the interconnect cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Backbone One Direction Pad Replacement, Disconnect the interconnect cable: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Direction Pad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Backbone One Direction Pad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the upper half of the left controller assembly.
  7. Backbone One Direction Pad Replacement, Remove the screw: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Backbone One Direction Pad Replacement, Remove the screw: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Direction Pad Replacement, Remove the trigger: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Backbone One Direction Pad Replacement, Remove the trigger: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the left trigger.
  9. Backbone One Direction Pad Replacement, Remove the bumper: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Backbone One Direction Pad Replacement, Remove the bumper: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the left bumper.
  10. Backbone One Direction Pad Replacement, Remove the screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws.
  11. Backbone One Direction Pad Replacement, Remove the mainboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Backbone One Direction Pad Replacement, Remove the mainboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the mainboard.
  12. Backbone One Direction Pad Replacement, Remove the direction pad: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Backbone One Direction Pad Replacement, Remove the direction pad: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Backbone One Direction Pad Replacement, Remove the direction pad: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of blunt nose tweezers to remove the direction pad.
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58 503 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 466crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 2,423
