Back Case
crwdns2869540:0crwdne2869540:0: 1352
4
20
89
1,352
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
Back Case
Are you trying to figure out what is wrong with your camera? This is a good place to start as it allows you to access everything in the camera that could possibly be wrong.
    1. Back Case, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient camera to look directly at battery compartment side as shown.
    2. Back Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Back Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Back Case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the two latches on the battery compartment.
      • First, move the "lock" switch left to reveal red indicator.
      • Next, move the "cover latch" switch downward to reveal red indicator.
      • You have to move the switches in that order for the compartment to unlatch.
    3. Back Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Back Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Allow the battery compartment latch to completely open.
      • Insert battery with the writing face up.
      • The bigger slot is for the battery. The smaller slot is for the memory card.
      • Battery not shown.
    1. Back Case, Back Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient the camera so you are looking at the bottom.
      • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
    2. Back Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient the camera so you are looking at the side plate.
      • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
    3. Back Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Back Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Orient the camera so you are looking at the front plate.
      • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
      • Remove the "Olympus" plate.
    4. Back Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove face plate.
    5. Back Case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Back Case: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Back Case: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate three small black screws inside of the battery compartment.
      • Remove the 3.85mm Phillips #00 screw on the far left side.
      • Remove the two 5mm Phillips #00 screws on the right side
    6. Back Case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Back Case: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Back Case: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Orient the camera to be look at the top.
      • Remove the 5.4mm Phillips #00 screw on the top left side.
      • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
      • Pry off top button plate with black nylon spudger.
    7. Back Case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Back Case: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Rotate to bottom of camera and locate bottom latch.
      • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
      • Push firmly apart.
      • Some buttons might fall out.
    8. Back Case: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Back Case: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Back Case: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Orient the camera to the LCD screen side that is now wedged open.
      • Locate the white ribbon cable and pull out from motherboard.
      • Locate the brown ribbon cable and pull out from motherboard.
Larissa Knight
crwdns2935283:003/21/16crwdne2935283:0
549 crwdns2915208:0crwdne2915208:0
Clemson, Team 7-2, Benson Spring 2016 crwdns2935289:0Clemson, Team 7-2, Benson Spring 2016crwdne2935289:0
CLEM-BENSON-S16S7G2
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 89
crwdns2959996:0crwdne2959996:0 1,352
