crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0BSP-D9crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. BSP-D9 Teardown, Opening the controller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To open the controller there are 8 screws on the rear that need to be remove to access either side of the controller.
  2. BSP-D9 Teardown, Opening the left side: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BSP-D9 Teardown, Opening the left side: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We start with the left side as the battery is this side.
    • Start by squeezing the indicated area with your thumb
    • Then twist whilst pressing the squeezed area to open the controller to the left similarly to a book. As shown in the second image
  3. BSP-D9 Teardown, Disconnecting cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BSP-D9 Teardown, Disconnecting cables: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 4 connections hold the top piece in as labelled
    • 1. Rumble motor connection
    • 2. Macro Button connection
    • 3. Battery connection
    • 4. Interconnect Flex Cable
    • Disconnect the battery first before disconnecting anything.
    • To disconnect the ZIF connector by picking on the grey bale. As shown
  4. BSP-D9 Teardown, Left Side PCB Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In order to remove the PCB, unscrew the two screws as shown
  5. BSP-D9 Teardown, Left Side Toredown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • And with that the left side is tore down.
  6. BSP-D9 Teardown, Right Side Opening: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BSP-D9 Teardown, Right Side Opening: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply pressure in the region highlighted in the images.
    • After which twist the controller in the direction shown
  7. BSP-D9 Teardown, Right Side Cable Disconnect: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 3 connections for the right side.
    • 1. Interconnect Flex Cable Connector
    • 2. Rumble Motor Connector
    • 3. Macro button Connector
    • To disconnect the flex cable follow the same steps as the left side
  8. BSP-D9 Teardown, Removing the mainboard (R): crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws highlighted in the image
  9. BSP-D9 Teardown, Right Side Toredown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • That's the right side torn down.
Neville Davids
crwdns2935283:007/02/18crwdne2935283:0
766 crwdns2915208:0crwdne2915208:0
What about the middle, extensible part? My Bsp-D9 stops working when fully extended, I think that part might be the problem.
Maxime Lumeau - crwdns2934203:0crwdne2934203:0
Hi there @maximelumeau It's possible that either the ribbon cable that connects both sides is broken or it has come disconnected.
The only way to check is check continuity using a multimeter for each connection in the ribbon cable or replace the ribbon cable with one of same specification respectively
Neville Davids -
What type of flex cable is that and how many pins are in it . Also do you know the space between the pins
Daniel Pax - crwdns2934203:0crwdne2934203:0
15 pin cable not sure of the pitch as I don't have a clamp to confirm the pitch
Neville Davids -
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 106
crwdns2942667:0crwdne2942667:0 2,172
