crwdns2959928:0crwdne2959928:0 ↓Using a hex 2.0 driver, you will take off the top cover in order to access the modem. With a pair of tweezers you will be able to remove and replace the modem.
Place the face of the device showing BRCK face up.
Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
Cut the black zip tie holding the modem down.
Remove the connection located on the edge of the modem.
Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
Lower the plate and gently pull the ribbon out of the face plate.
