BRAUN Cruzer 5 - Battery Replacement
  1. BRAUN Cruzer 5 - Battery Replacement, Trimmer Head removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BRAUN Cruzer 5 - Battery Replacement, Trimmer Head removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BRAUN Cruzer 5 - Battery Replacement, Trimmer Head removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the trimmer head.
    • Remove the two Torx T5 screws attaching the cover to the hand-piece.
    • Remove the cover.
    • Take this opportunity to remove built up hair and residue. Hair can prevent the batteries from making contact leading to power failure.
  2. BRAUN Cruzer 5 - Battery Replacement, Back cover removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BRAUN Cruzer 5 - Battery Replacement, Back cover removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BRAUN Cruzer 5 - Battery Replacement, Back cover removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back cover.
    • Using a flat head screw driver, remove the single screw holding the power board in place.
    • Use compressed air to clean the motor. Lubricate the trimmer with a suitable lubricant.
    • Remove the two AAA batteries by de-soldering them with a soldering iron and de-soldering pump.
    • Bend the terminals of the new batteries and solder them back in the right direction
    • If the batteries are already slightly charged, you can briefly press the power button to check if the motor is working
    • Insert the board again, with the side towards the motor first
  3. BRAUN Cruzer 5 - Battery Replacement, Front Cover removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BRAUN Cruzer 5 - Battery Replacement, Front Cover removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BRAUN Cruzer 5 - Battery Replacement, Front Cover removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the front cover of the device.
    • Clean and lubricate this area thoroughly as well, then your device will run better.
crwdns2935229:024crwdne2935229:0
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Zweikeks
crwdns2935283:012/16/15crwdne2935283:0
599 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Your guide saved me from purchasing a new device.
After replacing the batteries it works again like a charm!
King Arthur - crwdns2934203:0crwdne2934203:0
Thanks this was helpful. The Braun Series 3 Hair Clipper HC3050 has a VERY similar design. Some additional notes: After removing the screws, it takes a bit of force to get the back separated from the front. I had to gently pry it apart with a screw driver. The very inside is slightly different, but same concept.
Jaden Fox - crwdns2934203:0crwdne2934203:0
Die Anleitung war sehr hilfreich.
Der Austausch der Batterien ging ziemlich gut.
Wilhelm Gregorius - crwdns2934203:0crwdne2934203:0
I think one pcc— 1.2 V 1800 mah AA battary
Ünsal Şeker - crwdns2934203:0crwdne2934203:0
Thank you! Another appliance reborn :)
It really helps to work around consumerism with such shared knowledge!
Keep it up 👍
Pedro Faria - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 78
crwdns2936753:030crwdne2936753:0 346
crwdns2942667:0crwdne2942667:0 33,108
