BQP2-4.7 Freezer Relay Repair
  1. BQP2-4.7 Freezer Relay Repair, Inspect your relay: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The burnt out relay. Notice the brown heat marks. This picture is with the insides already removed, so yours will show leads.
  2. BQP2-4.7 Freezer Relay Repair, Disassemble the QP2-4R7 and BQP2-4.7: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BQP2-4.7 Freezer Relay Repair, Disassemble the QP2-4R7 and BQP2-4.7: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BQP2-4.7 Freezer Relay Repair, Disassemble the QP2-4R7 and BQP2-4.7: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the bottom off the QP2-4R7. You may break the tabs on the bottom plate, but that's OK since we don't need the housing. Look inside and you'll see the disc held in by a short metal brace. Use pliers to remove the brace and remove the disc.
    • Repeat the process for the BQP2-4.7, but be careful not to damage the housing if you can.
  3. BQP2-4.7 Freezer Relay Repair, Inspect the parts: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Notice the burnt out component in the red box vs. the shiny new one in the green box.
    • Clean the leads on the BQP2-4.7 of any residue to ensure a good connection to the new thermistor disc.
    • Reassemble the BQP2-4.7 by first inserting the leads, then pushing the disc between the connectors, and finally snapping the cover plate back on.
    • If you have an ohmmeter, check that you read about 4.7 ohms across the leads at room temperature.
Put the relay back into your freezer and test it out.
Be aware that the freezer will only turn on if the disc is cool, so if it turns on at first and you turn the freezer off, it probably won't immediately turn on again because the thermistor is already warm. Give it 5 minutes and try again.
crwdns2935229:011crwdne2935229:0
Perry Tancredi
crwdns2935283:011/29/12crwdne2935283:0
416 crwdns2915208:0crwdne2915208:0
crwdns2947412:016crwdne2947412:0
Good instructions; I tried doing this and was helpful. I found the actual part; it’s now available on amazon. [|Check here:] https://www.amazon.com/gp/offer-listing/...
MAZANDU mazandu - crwdns2934203:0crwdne2934203:0
Thanks! I’m glad this has helped some folks and I’m glad you got the part. I just checked that link and they’re no longer available. When I found them, they were five times as expensive as the other relay, but in the end the money might be worth it. I happened to have the other part, so thought I’d try the rebuild.
Perry Tancredi -
How long should a working disk take before it clicks off? Mine seems to get too hot after 10-20 seconds, but I see nothing obviously burnt.
rdrey1 - crwdns2934203:0crwdne2934203:0
Hi - it should only take a few seconds. 10-20 seconds sounds like too much, like it’s not stepping down for some reason.
Perry Tancredi -
I have a JPQii 4.7 two pin relay and cannot find a replacement. The one I have is new but reads 0 ohms
stevebevan232 - crwdns2934203:0crwdne2934203:0
There are universal relay kits or you could jury-rig some other less expensive relay if you know the connections. Another option is to use a Supco 3-in-1 hard start kit, which I’ve used on one large freezer once that kept failing and had good results. Those kits are less susceptible to failing than the relays as I understand it. I’m no expert though, so you may want to do your research first.
Perry Tancredi -
I just cleaned and polished the thermistor disk and the leads. The resistance reads now 12 ohm (was 8 K before). Can I put it back into the freezer of the disk does need to be replaced with a new one?
My relay is BQP2 TY (not 4.7) so I believe originally the resistance was also 12 ohms.
If I have to use a new disk, would the 4.7 ohm disc be OK in this relay?
Andrew D - crwdns2934203:0crwdne2934203:0
Hi - I have a BQP2 TY relay. It does not say the resistance. On the burnt thermistor it says A507 and 0924 but I cannot find any info on it.
After I cleaned the burnt resistor it reads 12 ohms
Would this 4.7 ohm thermistor work in that relay?
Hi Andrew, sorry I never saw this! I _think_ the BQP2 TY is the same part. If you look at the first picture my part says “BQP2 4.7 TY”. That said I don’t know for sure. I don’t think the starting resistance matters as much as the resistance once it heats up. If I wanted to test that, I’d put it in and make sure that after a few seconds the compressor is on and the relay has increased resistance enough to turn the coil off. The short answer is I don’t know, and hopefully you’ve figured it out by now one year later.
Perry Tancredi -
This is awesome! Had a kegerator that called for that part, and there weren’t any. The QP2-4R7’s were available for cheap! Took about 5 min. and had everything up and going again! THANK YOU SO MUCH!
Ron Greer - crwdns2934203:0crwdne2934203:0
Excellent! I’m so glad it’s helping!
Perry Tancredi -
I also need a jp q 2 4.7 2 pin relaycannot findone anywhere,compressor in whirrpool mini fridge is a foreign name,has anyone found a fixive tried the opening up a 3 pin and using the guyt outof it but was not successful
charlie w smith - crwdns2934203:0crwdne2934203:0
I have a haier ZHBCNO5FVS trying to remove wite for existing starter relay plug the wire is not coming off. How do I get it off?it has 2 wires on the one prong and not coming off.
Help please
Tiffany Johnson - crwdns2934203:0crwdne2934203:0
I also could not find this part so coming across your instructions was fantastic. Since it is a disc I cleaned my old one and then rotated it 90degrees to the undamaged area. Mine just had some localized pits where the two contact points were. Rotating it got the freezer going again. I will probably either find a thermistor disc off some other unit and keep it as a spare. Thanks again for the great and informative instructions here.
Kerry Lee - crwdns2934203:0crwdne2934203:0
Thanks for posting this - I'm so glad this is helping people so many years later!
Perry Tancredi -
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 230
crwdns2942667:0crwdne2942667:0 23,322
