BOSE SoundTouch 30 Speakers Replacement
  1. BOSE SoundTouch 30 Speakers Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BOSE SoundTouch 30 Speakers Replacement, Base Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Speakers Replacement, Power Supply: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
  3. BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    Is there any way to replace or repair the display ribbon cable? I snapped it and now I have no display.
    Carol Rigdon - crwdns2934203:0crwdne2934203:0
  4. BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
    I can buy the parts with you guys.
    Jaime Ojeda - crwdns2934203:0crwdne2934203:0
  5. BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
    actually there are four connections - one underneath at the top of the picture above
    Simon Ward - crwdns2934203:0crwdne2934203:0
  6. BOSE SoundTouch 30 Speakers Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BOSE SoundTouch 30 Speakers Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BOSE SoundTouch 30 Speakers Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 15.5 mm PH2 screws holding the motherboard down.
    • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
    • Remove the motherboard.
    • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
    hello there,
    I need a replacement of my motherboard, where can I buy this item?
    Thank you..
    edgar - crwdns2934203:0crwdne2934203:0
  7. BOSE SoundTouch 30 Speakers Replacement, Speakers: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 15.5 mm PH2 screws holding the plastic insert down.
    • Remove the plastic insert and set it to the side.
  8. BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 15.5 mm PH2 screws holding the metal insert down.
    • Remove the metal insert and set it to the side.
    You need to remove the plastic cover 1st before the metal piece
  9. BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 15.5 mm PH2 screws securing the side plates to the front of the device.
    • Remove the six 15.5 mm PH2 screws securing the side plates to the back of the device.
    • The foam lining can cover up a screw. If you can't see all three right away, lift up along the edge of the foam until all screws are found.
  10. BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the device on its back and remove the four 11 mm PH0 screws holding the speaker to the device.
    • Remove the four 11 mm PH0 from the other speaker as well.
    • The screws on the speakers can be extremely tight and might require the use of a screwdriver with a large handle.
    Onde posso comprar novos speakers ?
    faria34faray - crwdns2934203:0crwdne2934203:0
  11. BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BOSE SoundTouch 30 Speakers Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speakers from their housings, making sure to be careful with the wires.
    • Unhook the speaker wires from the cable stays along the sides and bottom of the device.
Brennen Irey
crwdns2935283:004/18/18crwdne2935283:0
1,221 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S16-G2, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S16-G2, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S16G2
crwdns2947412:05crwdne2947412:0
Hi can I buy the subwoofer that needs replacing I am in Australia.
Michael - crwdns2934203:0crwdne2934203:0
I need power supply PCB having part number 353846-0080 printed on it. Please send quote to e mail: vgvachhani766@gmail.com
Thanks
Vasantray - crwdns2934203:0crwdne2934203:0
I also require a PCB - part number 353846-0080
Akash - crwdns2934203:0crwdne2934203:0
Jo, I need Bosé SOUNDTOUCH 30 Diagram
Aulo Pavón - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 111
crwdns2942667:0crwdne2942667:0 9,769
