This guide will show the steps needed to remove the power supply from the BOSE SoundTouch 30.
Remove the four 15.5 mm PH2 screws securing the base plate to the device.
Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
Is there any way to replace or repair the display ribbon cable? I snapped it and now I have no display.
Remove all four 15.5 mm PH2 screws holding the power supply down.
Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
Pick up the power supply and remove the fourth cable from the underside of the power supply.
Remove the power supply.
actually there are four connections - one underneath at the top of the picture above
crwdns2935229:012crwdne2935229:0
crwdns2947412:030crwdne2947412:0
where can we buy the [power supply unit, as i have messed mine by using 220v instead of 110v
Hello. Do you want to exchange power supplies?
Contact me please!
Hi. My name Josley from Brazil.
I need you Power supply module for bose soundtouch 30.
You can help me?
Hola donde puedo comprar el modulo SoundTouch 30 Power Supply.
Muchas gracias.
Isidro -
I have the opposite problem. Bought the 110v instead of the 220v and now I have to use a step down transformer. Wanna exchange power supplies?
tomas@familiarosales.cl
where did you buy the power supply?
Do you want to sell the Bose 110v powersupply
Steve -
Hi, are you still interested in a board with 220v? I need a board with 120v?
how do I buy a new power unit?
Hi William
Im Kevin from Sydney, Australia.
I’d like to buy a power supply module for SoundTouch 30 as well but I cannot find anywhere.
Please let me know if you got any good news.
Cheers!
Kev
I’m from Adelaide, Australia and would love to know where I can get a 220v power supply?
The part number of the 220V power supply is 354778-002S. I’ll check the BOSE service center here in the Philippines if they have stock. I’m also going to replace it because someone plug that US version to our 220V outlet.
Hi!. I have two units don´t sound it!. The subwoofer and speakers are good, because I tested it!. Also, I did fabrica reset it and I configured again!. Do you know if that fault is about motherboard o power supply PCB?
Hi, same problem… plugged a 110V unit into 220V outlet… need a new power supply… anything that will work, even if have to use a step-up transformer…
I am also looking for the replacement power board, BOSE offered to ‘look’ at the unit but the price was 70% of a new Bose 30!
I would like to thank Electronic Partners (www.electronic.partners) who not only repaired my power board at the component level but converted it to 240V. Works like a dream. Now I don’t have to junk a perfectly good sound system.
Hi,
My name is Isidro, where can we buy the part component BOSE SoundTouch 30 Power Supply
Hi Tomas,
We bought our Soundtouch30 in the USA. We have moved to Portugal where they have 220V. Can we just change the power supply in order for it to work in Portugal?
Where can I buy the power supply board, I’m in USA?
Ich bräuchte ebenfalls das Netzteil(Modul). Kann mir jemand weiterhelfen?
I think this is a power supply to replacement.
Hi, do you know if this spare part worked on a Bose sound touch 30?
I need a power supply for Bose soundtoich 30. If some one wants to buy let.me know
Hi, I am interested in a 120V power supply for SoundTouch 30. Do you have one?
Hi I have bose cinemate 120 system on that control console not coming display on display board
Let me know remedies
Does anyone have 220V power supply?
Hi, I have a Bose SoundTouch 30 with 220V and would like to switch to 120V. Do you have a 120V power supply board?
I have a Bose Soundtouch 30 series iii US version 110V and it was plugged into 220V wall outlet. I opened it up and saw 2 blown out transistors (maybe?) I could only read half of the components part number as the half of it was blown out.
F 1F11AA
FCD
7N60
Could anyone please tell me what is the complete part number so I can try to order them on digikey? Please?
Where do I buy the110 power supply for the Bose 30
Hello My name is Emmanuel from Cameroon.
Please I need a Bose Soundtouch 30 power supply. Where can I get it please?
