BOSE SoundTouch 30 Display Assembly Replacement
  1. BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Display Assembly Replacement, Display Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 15.5mm PH2 screws holding the front-mesh grille in place.
  3. BOSE SoundTouch 30 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the grille by gripping the edges and pulling upwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    What happens if you do snap the ribbon cable? Where and how can you find a replacement for it?
    Tria Green - crwdns2934203:0crwdne2934203:0
  4. BOSE SoundTouch 30 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BOSE SoundTouch 30 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 8.9mm T9 torx screws holding the display assembly down.
    • The display assembly can now be lifted out of the grille so that a new one can be put in.
    How can I order this display assebly part
    mjeannette772 - crwdns2934203:0crwdne2934203:0
Brennen Irey
crwdns2935283:004/18/18crwdne2935283:0
1,221 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S16-G2, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S16-G2, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S16G2
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 4,511
