The motor in the machine starts, but nothing moves? The belt is probably torn, which you can get for a lot of money from BOSCH or, if you know what to look for, from other dealers directly.
Here are the instructions for replacing the belts.
Open 4 cross screws
Loosen some plastic latches
Simply "pull off" the knob while or before opening the housing
Loosen screw
Turn back the plastic-tensioner so that the gear seperates from the rest
Pull the black cap off the axle
Flip the longer belt over the pulley
Unscrew 3 screws to remove the plastic cover
Lever out the clamps to remove the axle and take out the belts
Remove the clutch / gearbox
Insert new belts with the axle
Tension the 3M belts and reassemble everything
Work through the steps in reverse order to reassemble your unit.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0Moritz Grafcrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
