This guide will help you replace a burnt out tail light on your 2003-2010 BMW 5 Series car. Neglecting regular car maintenance such as changing a tail light can cause many problems including a ticket or worst.
This is a quick and easy job that any one can do and you’ll save money too. Follow this step-by-step guide to change the tail light on your 2003-2010 BMW 5 Series.
Open the trunk of the car to access the tail lights.
Remove the two 5 mm screws holding the panel cover in place.
With a flathead screwdriver, turn the screws half a turn counterclockwise.
Pull up the trunk matt and remove it from the corner.
Pull up the panel by the tab.
Turn the dial in the middle of of the black plastic light bulb holster.
Pull the holster out of the trunk bay.
Grab the light bulb at the base and twist counterclockwise.
Pull out the bulb and repeat the process in reverse order with the new bulb to reassemble.
To reassemble, follow these instructions in reverse order.
