BMS Replacement Replacement
  1. BMS Replacement Replacement, Set up: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start with a clean work bench
    • Remove all conductive a tools from your work bench
    • Wear safety glasses
  2. BMS Replacement Replacement, Open the case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Open the case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Open the case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a stanley knife to cut though the sealant of the battery case
    • Use caution when doing this
  3. BMS Replacement Replacement, Start opening the case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BMS Replacement Replacement, Start opening the case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly lever the case apart.
    • Start at the bottom and work your way around to the handle
  4. BMS Replacement Replacement, Completely open the case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Completely open the case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Completely open the case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fully open the case
    • The glue is quite strong, use you hand inside to seperate the case from the heat shrink
    • Be careful to not damage the delicate switch wires
  5. BMS Replacement Replacement, Removing the battery pack: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Removing the battery pack: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Removing the battery pack: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut off the thick black shrink wrap
    • The main power cables and switch remain connected to the top cover.
    • Gently release and remove the switch cables from any adhesive so that they are not under stain when opening the case.
    • Rest the top cover on a box or similar to prevent staining the cables
  6. BMS Replacement Replacement, Remove heat shrink: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Remove heat shrink: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Remove heat shrink: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the heat shrink from the battery pack.
    • go slowly at the cable end as to not break or stain any thinn switch cables
  7. BMS Replacement Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BMS Replacement Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fiberglass sheeting from the pack
  8. BMS Replacement Replacement, Remove the negative terminal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BMS Replacement Replacement, Remove the negative terminal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the negative terminal
    • Cover the negative terminal with tape
  9. BMS Replacement Replacement, Disconnect old BMS: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Disconnect old BMS: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Disconnect old BMS: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the 4 connectors from the BMS. these will all be reused. do not cut.
    • Cut the large main negative cables from the BMS. There are 3-4 at each end of the BMS.
  10. BMS Replacement Replacement, Cut switch light wire: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BMS Replacement Replacement, Cut switch light wire: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut the black switch light wire as close to the BMS as possible.
    • A connector is soldered to this in step 14
  11. BMS Replacement Replacement, Remove old BMS: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Remove old BMS: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Remove old BMS: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fully remove old BMS
    • Desolder short wires from the main negative
    • Ensure all old solder locations are smooth
  12. BMS Replacement Replacement, Prepare New BMS: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Prepare New BMS: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Prepare New BMS: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove fibreglass from old BMS and install on New BMS
    • Locate new BMS as shown
    • Solder main Negatives as shown
    • The new BMS has all of the connections from one end only.
  13. BMS Replacement Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BMS Replacement Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Only after soldering the main negative plug in the ballance, switch and temperature connections
    • Arrange as neatly as possible to avoid pinch points
    • Tape down to secure BMS in place
  14. BMS Replacement Replacement, Switch light cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The light for the switch is illuminated when the pack is turned.
    • Solder or crimp the eye terminal to the switch light wire that was cut in step 10
  15. BMS Replacement Replacement, Cable Routing: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Cable Routing: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Cable Routing: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The New BMS has different cable routing than the old one
    • Cut a slot in the fibreglass for the for the new BMS cables
    • Wrap the fiberglass sheets back around the BMS
    • Use duct of fiberglass tape close and seal the fiberglass sheets around the battery pack
  16. BMS Replacement Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BMS Replacement Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect the main negative to the terminal on the battery case.
    • Correct order is Terminal - main negative lug - eyelet - bolt
  17. BMS Replacement Replacement, Functionality check: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BMS Replacement Replacement, Functionality check: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the switch on and off to check that the red light turns on and off.
    • Check the BMS app to ensure the all cells and connected to the ballance leads
    • Use ant BMS V2 app from the app store
  18. BMS Replacement Replacement, Heat shrink the pack: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Heat shrink the pack: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BMS Replacement Replacement, Heat shrink the pack: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
Mark Duyvesteyn
crwdns2935283:002/11/26crwdne2935283:0
1,269 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 70
