Use this guide in order to successfully remove and replace the rear-facing camera on your BLU Studio 5.0 II phone.
Locate the small opening on the bottom corner of the back case.
Use your finger to open the back case by slowly pulling it on the open slot.
Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
Locate the opening slot at the bottom of the battery.
Use your finger to lift the battery and remove it from the case.
Locate the four 3mm screws on each side of the back panel.
Use a Phillips #00 screwdriver to remove the eight screws.
Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
With the help of your fingers, continue to remove the back case by sliding it through the opening.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Locate the camera, which is centered on the upper part of the motherboard.
Use tweezers to lift the camera slowly.
Carefully pull the camera out of the motherboard.
