Replace your broken rear-facing camera with this guide. Be careful not to tear the ribbon cables or break the arms of the plastic plates as they are fragile.
Be sure that your BLU R2 Plus is completely powered off and has less than 25% battery left. This will lower the chance of your battery catching fire and your logic board/motherboard shorting out.
Insert your pick in the top left-hand corner where the little indent is.
Slide the pick all the way around the phone until the back cover is loose and ready to be released.
Remove the Back Cover to gain access to sim card trays, the memory card slot, or just to replace it.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$17.96
Use a Phillips #00 screwdriver to remove the 9 screws from the upper plastic plate.
Use an opening pick to unclip the upper plastic plate from the phone.
Once unclipped, slide it up and out of the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a spudger to unclip the ribbon cable from the motherboard/logic board. Carefully use blunt tweezers or angled tweezers to pull the ribbon cable out of the socket. Then use the tweezers to wiggle the camera out of its socket.
