BLU Life XL Charging Port Replacement
  1. BLU Life XL Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BLU Life XL Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BLU Life XL Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
  2. BLU Life XL Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BLU Life XL Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BLU Life XL Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the old battery.
    • For optimal performance, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
  3. BLU Life XL Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BLU Life XL Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove twelve 3mm Phillips #000 screws from the rear plate.
  4. BLU Life XL Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BLU Life XL Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic frame on the device using an opening tool.
    • Firmly press the tool into the gap between the front glass and rear plate.
    • The gap is located on all sides of the phone.
    • Run the tool through this gap along the entire edge of the phone to separate the plastic frame from the phone.
  5. BLU Life XL Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BLU Life XL Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BLU Life XL Charging Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect lower PCB antenna connection.
    • Disconnect lower PCB data cable connection.
    • Remove the single JIS #000 3mm screw from the PCB board.
  6. BLU Life XL Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the haptic motor at bottom left of the device. This will require a prying tool, as the motor is glued to the device.
Euan Gordon
crwdns2935283:002/14/18crwdne2935283:0
164 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G5, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S2-G5, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S2G5
crwdns2942667:0crwdne2942667:0 2,113
