BLU Life X8 Daughterboard Replacement
  1. BLU Life X8 Daughterboard  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BLU Life X8 Daughterboard  Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Daughterboard  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Daughterboard  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Daughterboard  Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BLU Life X8 Daughterboard  Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
  5. BLU Life X8 Daughterboard  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
  6. BLU Life X8 Daughterboard  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the clips have been released, lift the frame and set it aside.
  7. BLU Life X8 Daughterboard  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BLU Life X8 Daughterboard  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
  8. BLU Life X8 Daughterboard  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BLU Life X8 Daughterboard  Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BLU Life X8 Daughterboard  Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
  9. BLU Life X8 Daughterboard  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
  10. BLU Life X8 Daughterboard  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift the vibration motor away from the frame and peel up the tape.
  11. BLU Life X8 Daughterboard  Replacement, Daughterboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
  12. BLU Life X8 Daughterboard  Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the transparent tape covering one of the ribbon connectors using the tweezers.
  13. BLU Life X8 Daughterboard  Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BLU Life X8 Daughterboard  Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BLU Life X8 Daughterboard  Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to lift the black and beige tabs securing the ribbon cables.
    • Pull back on the ribbon cables to release them from their connectors.
  14. BLU Life X8 Daughterboard  Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the daughterboard from the frame using the plastic opening tool.
Nicholas Harmon
crwdns2935283:010/05/17crwdne2935283:0
160 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G2, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S1-G2, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S1G2
crwdns2942667:0crwdne2942667:0 286
