This guide will take a bit of time so make sure your schedule is free before you attack this guide! If you have no soldering experience I suggest looking at Ifixits guide on soldering here.
Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
Using a plastic opening tool or finger, pull out the battery.
Remove the four 4.0mm Phillips #1 screws.
Starting from a corner, separate the panel from the frame using the plastic opening tool.
Unscrew the 3.6mm Phillips #0 screw from the motherboard.
Using a spudger, lift the black ZIF connector at the top left corner of the phone.
Pull the ribbon cable out of the ZIF connector.
When the ribbon cable is removed from the ZIF connector, peel off the power sticky button using a plastic opening tool.
Separate the screen cover from the motherboard using the plastic opening tool.
The microphone is at the bottom left corner of the phone.
Lift the microphone very carefully. Unsolder the two lower wires (one red wire and one black wire).
Solder the new microphone in the same spot. The black wire will go in the left spot and the red wire in the right spot.
