BLU Advance 4.0 Charger Port Replacement
  1. BLU Advance 4.0 Charger Port Replacement, Removing the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BLU Advance 4.0 Charger Port Replacement, Removing the back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Charger Port Replacement, Separating motherboard from screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
  4. BLU Advance 4.0 Charger Port Replacement, Charger Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BLU Advance 4.0 Charger Port Replacement, Charger Port: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once phone is completely disassmbled, you will take your soldering iron to the charger port to remove it.
    • Be careful to make sure you take a soldering wick to absorb the solder.
    • Touching other pieces on the motherboard may alter phones capabilities!
  5. BLU Advance 4.0 Charger Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the old charger port is removed, take the new one and place it in the same spot. You will need to solder this piece to ensure that it stays connected.
Jon Sclar
crwdns2935283:011/13/14crwdne2935283:0
292 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 crwdns2935289:0UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014crwdne2935289:0
UMASSD-VIJAYBHASKAR-F14S6G2
Where can I get a charging port for my BLU studio XL2
Debbie - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,600
