BEM Mojo 2 Speaker Replacement
  1. BEM Mojo 2 Speaker Replacement, Speaker Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
  6. BEM Mojo 2 Speaker Replacement, Speaker Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
  7. BEM Mojo 2 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red/black wires in addition to the blue/white wires using the tweezers.
  8. BEM Mojo 2 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
  9. BEM Mojo 2 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any glue that is left over from previous parts that may be covering the screw holes or the speakers drive.
  10. BEM Mojo 2 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BEM Mojo 2 Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker's four 10 mm base screws.
  11. BEM Mojo 2 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BEM Mojo 2 Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry out the speaker's base using the metal Spuger. Use caution upon this step, it will require the use of force.
    • Remove the wire that will be placed in the speakers driver hole for access to the speaker.
  12. BEM Mojo 2 Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 BEM Mojo 2 Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker's two 10 mm screws that are located in its base then take the driver out of the speaker.
Rachel Iacoboni
crwdns2935283:001/30/18crwdne2935283:0
618 crwdns2915208:0crwdne2915208:0
Baylor, Team S1-G1, Johnson Spring 2018 crwdns2935289:0Baylor, Team S1-G1, Johnson Spring 2018crwdne2935289:0
BU-JOHNSON-S18S1G1
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 479
