Azpen A909 Speaker Replacement
  1. Azpen A909 Speaker Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
  4. Azpen A909 Speaker Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently peel back the black electrical tape covering the contact points between the speaker wires and the circuit board. The contact points are marked with a red box.
  5. Azpen A909 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you start soldering, it may be a good idea to check out the soldering and desoldering guide.
    • Melt the solder around the contact points with a soldering iron while using a de-soldering wick to absorb the melted solder.
    • Once the solder is removed from the contact points, pull the wires away from the circuit board contacts.
    • When attaching a new speaker, do not solder the two contact points together.
Karoly Fodor
crwdns2935283:003/15/15crwdne2935283:0
475 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-5, Duarte Spring 2015 crwdns2935289:0UMass Dartmouth, Team 3-5, Duarte Spring 2015crwdne2935289:0
UMASSD-DUARTE-S15S3G5
crwdns2942667:0crwdne2942667:0 238
