crwdns2959928:0crwdne2959928:0 ↓The battery is important for all tablet functions. If the battery is malfunctioning you will want to replace it. Replacing your battery is a relatively simple task and following this guide will help you fix your battery related problems.
Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
Locate the batteries' connection points.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a soldering iron to melt the connections which attach the battery to the motherboard.
Disconnect the red and black wires from the motherboard.
Peel the black sticker off the battery to disconnect the wifi antennae.
Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
Remove the old battery and replace it with the new battery.
