The screen assembly is located underneath all of the other parts of the device. To access it, you will have to remove these pieces first. Make sure to keep track of all five screws and any connected parts.
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Pry open the back piece with the plastic spudger.
Remove the back piece from the device.
Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
Gently pry the battery off of the device with the plastic spudger.
Disconnect the two largest (of the three) ZIF cables by prying open the flap with a plastic spudger to gently remove them.
Peel off the black tape from the corner of the motherboard (indicated by the blue surface of the device).
Use a Phillips #000 screwdriver to remove the three screws that connect the motherboard to the front panel.
Remove the motherboard and the battery and set aside.
Remove the small orange tape attached with a gray wire from the top corner of the device. This is the antenna.
Use a plastic spudger around the silver lining within the device to pry the screen off.
Replace the broken screen and reverse the steps to re-assemble the device.
