Azpen A701 Motherboard Replacement
  1. Azpen A701 Motherboard Replacement, General Disassembly Prerequisite Guide: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Azpen A701 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry open the back piece with the plastic spudger.
    • Remove the back piece from the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Azpen A701 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Azpen A701 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
  6. Azpen A701 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Azpen A701 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Azpen A701 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 2cm screws at the bottom using the Phillips PH00 screwdriver head.
  7. Azpen A701 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently peel off the orange sticker with the gray wire connected to the upper corner of the device. This is the antenna.
  8. Azpen A701 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove solder connecting the battery to the motherboard using the soldering kit.
    • Place battery aside.
    • For more information on soldering, refer to iFixit's Soldering Guide.
  9. Azpen A701 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove solder connecting the speaker wires to the motherboard.
    • Set speaker aside.
  10. Azpen A701 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove solder connection the gray antenna wire to the motherboard.
    • Set antenna aside.
  11. Azpen A701 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove motherboard from device.
  12. Azpen A701 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert new motherboard.
    • Replace all three 2cm screws at the bottom of the motherboard.
Michael
crwdns2935283:003/11/15crwdne2935283:0
568 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 2-1, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 2-1, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S2G1
crwdns2942667:0crwdne2942667:0 594
