This guide demonstrates how to remove the back panel and open the device for repairs and replacements.
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Pry open the back piece with the plastic spudger.
Remove the back piece from the device.
Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
Gently pry the battery off of the device with the plastic spudger.
