The battery in the A701 is located adjacent to the motherboard (the blue L-shaped piece) and has soldered wires. Before continuing, be sure you have all the necessary tools and safety equipment.
A guide to soldering can be found here.
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Pry open the back piece with the plastic spudger.
Remove the back piece from the device.
Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
Gently pry the battery off of the device with the plastic spudger.
Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
Insert new battery by soldering red and black wires onto the motherboard.
