This guide will show you how to properly replace the speaker in a Azpen 1045 tablet if your speaker is scratchy or blown out. These steps will show how to safely remove and install a new speaker.
Power off the tablet by holding the side button for five seconds.
Insert an opening tool into one of the sides and lift until the screen comes off.
If there is electrical tape covering the contacts on the motherboard, gently peel it back to expose the contacts.
With a soldering iron, carefully melt the two speaker contacts on the motherboard and use a desoldering wick to absorb the melted solder to prevent possible short circuits.
Take the new speaker and place it in the same location as the old speaker and screw it in place. With a soldering iron, carefully solder the wires back to the motherboard as they were with the old speaker.
