Azpen A1045 Charging Port Replacement
  1. Azpen A1045 Charging Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Azpen A1045 Charging Port Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the tablet by holding the side button for five seconds.
    • Insert an opening tool into one of the sides and lift until the screen comes off.
    • This tablet is secured by clips on the sides; no adhesive is used.
  2. Azpen A1045 Charging Port Replacement, Charging Port: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The charging port is located on the right-hand side when viewing the rear panel, just above the USB connector. It can be identified by the black square with a hole on the underside of the circuit board.
  3. Azpen A1045 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Azpen A1045 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Azpen A1045 Charging Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the circuit board, carefully peel off any tape securing it to the front panel. Gently disconnect the camera from the port in the upper corner of the panel.
    • Gently disconnect the two remaining orange ribbon connectors attached to the circuit board. Use an opening tool to lift and remove the circuit board from the front panel.
  4. Azpen A1045 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Azpen A1045 Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the charging port with a pair of tweezers. Solder the new charging port onto the circuit board using a soldering iron.
    • For more information on soldering, check out this guide.
James
crwdns2935283:003/26/25crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-1, Biswokarma Spring 2025 crwdns2935289:0UMass Dartmouth, Team 5-1, Biswokarma Spring 2025crwdne2935289:0
UMASSD-BISWOKARMA-S25S5G1
crwdns2931471:07crwdne2931471:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 71
