Axess TA2513-10WT Camera Replacement
  1. Axess TA2513-10WT Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Axess TA2513-10WT Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Axess TA2513-10WT Camera Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Camera Replacement, Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the tablet over. Locate the left screw.
    • Use the magnetic screwdriver to remove the left screw.
  6. Axess TA2513-10WT Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is a bottom screw located to the right of the left screw that was just removed.
    • Remove the bottom screw using the magnetic screwdriver.
  7. Axess TA2513-10WT Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the entire plastic cover using either tweezers or your fingers.
  8. Axess TA2513-10WT Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Brush the surfaces of the cameras to remove any debris that is present.
  9. Axess TA2513-10WT Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is a black plastic cover on the back of the tablet. It is attached to the ribbon cable.
    • Use tweezers to rotate the black plastic cover 90 degrees upwards.
    • Flip the cover up and pull out the ribbon cable.
  10. Axess TA2513-10WT Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable from the port.
Steven Kavanagh
crwdns2935283:003/24/15crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
Baylor, Team 6-3, Shaver Spring 2015 crwdns2935289:0Baylor, Team 6-3, Shaver Spring 2015crwdne2935289:0
BU-SHAVER-S15S6G3
crwdns2942667:0crwdne2942667:0 232
