Axess TA2513-10WT Battery Replacement
  1. Axess TA2513-10WT Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Axess TA2513-10WT Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Axess TA2513-10WT Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shove the Spudger below the battery pack to remove any tape or adhesive residue.
  6. Axess TA2513-10WT Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery up with your hands to ensure complete detachment from the screen.
  7. Axess TA2513-10WT Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the red wire attached to the node labeled "B+" and the black wire attached to the node labeled "B-"
  8. Axess TA2513-10WT Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the heated soldering iron down on the "B+" node while simultaneously tugging on the red wire.
  9. Axess TA2513-10WT Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red wire from the node labeled "B+"
  10. Axess TA2513-10WT Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the same process as the red wire, detach the black wire from the node labeled "B-".
  11. Axess TA2513-10WT Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery should now be separated from both the screen and circuit board
Steven Kavanagh
crwdns2935283:003/24/15crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
Baylor, Team 6-3, Shaver Spring 2015 crwdns2935289:0Baylor, Team 6-3, Shaver Spring 2015crwdne2935289:0
BU-SHAVER-S15S6G3
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 573
