Axe Empire 2.0 OLED Board Replacement
  1. Axe Empire 2.0 OLED Board Replacement, OLED Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement, OLED Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an Allen key to remove four total screws.
    • 2.5 mm screws.
    • 1.2 mm screw.
  2. Axe Empire 2.0 OLED Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press and hold the release button while lightly pulling the spring bolt out.
    • If the spring bolt has not been serviced with lube after a long time you might need to pull harder. This is a great time to lube the spring bolt.
  3. Axe Empire 2.0 OLED Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two main screws using a 2.5 mm Allen key to separate the air transfer plate from the frame.
  4. Axe Empire 2.0 OLED Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw using a 2.5 mm Allen key and remove the foregrip from the frame.
  5. Axe Empire 2.0 OLED Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1.2 mm Allen key to remove the screw, and remove the cover to expose the OLED Board.
  6. Axe Empire 2.0 OLED Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the last screw with a 2.5 mm Allen key to loosen the OLED Board.
    • Use a pick tool to carefully remove the battery and OLED Board together out of the foregrip.
    • Wear gloves in case battery is defective and leaking acid.
  7. Axe Empire 2.0 OLED Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Axe Empire 2.0 OLED Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery from the OLED board.
Christopher Ramos
crwdns2935283:010/05/21crwdne2935283:0
345 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 11-2, Grodsky Fall 2021 crwdns2935289:0CSU Los Angeles, Team 11-2, Grodsky Fall 2021crwdne2935289:0
CSULA-GRODSKY-F21S11G2
crwdns2942667:0crwdne2942667:0 301
