This guide covers removing the clear dome cover for the AvertX HD810 security camera. You need a T10 Torx security screwdriver and a replacement dome cover for the camera. It's advised to have the camera turned off for this procedure.
Lift off the paintable snap-on cover from the AvertX HD810 dome security camera.
Loosen both 10mm screws on either side of the clear dome cover housing using a T10 Torx security screwdriver.
Gently pull off the clear dome cover from the camera base.
You've successfully replaced your AvertX HD810 clear dome cover when you've snapped back on your paintable snap-on cover. You can reassemble your device at any point by following the steps in reverse order.
