Follow this guide to disengage the Auto-Feeder on your Electric Eel Drain Cleaner Z5K12IC75AF so the cable can pass through freely or removed.
Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
Remove the guide spring.
Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
Push the top control finger up as far as possible.
