Audiovox CR8030iE5 Top-Casing Replacement
  1. Audiovox CR8030iE5 Top-Casing Replacement, Top-Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Top-Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Top-Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Top-Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Top-Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
Savannah Smith
crwdns2935283:004/18/13crwdne2935283:0
51 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-39, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 10-39, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S10G39
crwdns2942667:0crwdne2942667:0 431
