Audiovox CR8030iE5 Power Adapter Replacement
  1. Audiovox CR8030iE5 Power Adapter Replacement, Top-Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Power Adapter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Power Adapter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Power Adapter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Power Adapter Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Power Adapter Replacement, Power Adapter: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • One by one, de-solder the two wires that connect the power adapter to your Audiovox.
    • If you don't know how to solder, check out How To Solder and Desolder Connections.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  7. Audiovox CR8030iE5 Power Adapter Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the wires of the new adapter into the designated holes and solder them into place.
Savannah Smith
crwdns2935283:004/18/13crwdne2935283:0
51 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-39, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 10-39, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S10G39
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 451
